Date/Time: Fri, 22 Nov 2024 08:26:53 +0000
Trade Alerts
View Count: 1827
[2013-05-03 01:30:49]
User23815 - Posts: 210
I checked the box under General Trade Alerts that says Play Alert When Order Filled (Others) and set it to Text me. I received 5 texts, all the same. Where can i set this so that I only receive a single notification for the order? Thanks
[2013-05-03 01:46:19]
If there were 5 fills, then you will get 5 messages. This is just how it works.
[2013-05-03 22:28:42]
theskillzdatklls - Posts: 8
There's at least one semi custom/fancy alert signal I'm looking to do that I can't figure out and possibly more later. Basic alerts I understand no problem. May I either pose the question here or is there someone that I can pay on a per-custom alert basis?
[2013-05-03 22:59:49]
There is definitely someone who can help you with alerts for a fee. Refer to sawtoothtrade.com :
http://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html
