Date/Time: Wed, 27 Nov 2024 14:19:42 +0000
Weekly Chart Candle is different between NQ and ES chart
View Count: 277
[2023-07-31 00:20:23]
User78682 - Posts: 7
Hi Support,
When using the intraday day chart setting 7-0-0, I have a difference between NQ and ES weekly chart, even though I duplicated the NQ chart from ES, the weekly candle does not show a new candle at 18:00 PM EST for the NQ chart, also, the day of starting weekly candle also different between the NQ and ES chart, while ES day is 7-9,7-13,7-23, NQ is 7-17,7-24,7-31 which the candle will no stat until Monday.
Please see attached photo for more information, thank you.
Derrik
Private File
[2023-07-31 10:45:33]
Sierra_Chart Engineering - Posts: 17193
The problem is each of these charts needs to be set to have the first day loaded to be a Sunday. This can be controlled through this particular setting:
Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu)
