Date/Time: Wed, 27 Nov 2024 14:21:48 +0000
AMP-Sierra connection issue
View Count: 248
[2023-07-30 07:20:18] |
User346931 - Posts: 6 |
Hi I just bought Denali - Service 10 package. However, when i connect with my AMP brokerage account, it shows error message with no data (see attached) Please help. |
AMP connection issue.PNG / V - Attached On 2023-07-30 07:19:51 UTC - Size: 6.32 KB - 78 views |
[2023-07-30 16:04:11] |
Sierra_Chart Engineering - Posts: 17193 |
Are you still seeing these errors? We see that you do have the necessary exchanges active. Be sure to deactivate what you do not need: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-30 16:04:49
