Date/Time: Mon, 14 Sep 2026 03:21:18 +0000
Backtesting Slippage
View Count: 2427
[2014-07-09 17:43:03]
ZH Support - Posts: 19
Support,
When backtesting a strategy on the charts is there a way to set the backtesting up for allowable slippage? To try and make the backtesting as realistic as possible.
Jake
[2014-07-10 05:32:00]
The back testing is very realistic for two reasons. The bid and ask prices are used to fill orders. This is explained in detail here:
Trade Simulation: How Orders are Filled
If you are running a current version of Sierra Chart, then as of June 23, 2014 actual bid and ask prices are stored historically and are used to fill orders during back testing.
To take advantage of this accurate back testing, refer to the documentation here:
Auto Trade System Back Testing: Using Actual Bid and Ask Prices During Back Test
[2014-07-10 17:28:18]
For an understanding about how a stop order is filled during simulation and at what price in Sierra Chart, refer to:
There is not a simple yes or no answer. There is no consideration of time.
Date Time Of Last Edit: 2014-07-10 17:29:07
