Date/Time: Mon, 16 Sep 2024 19:07:04 +0000
confusing entries on 2 laptops
View Count: 1973
[2014-07-09 16:46:56] |
User30743 - Posts: 364 |
hi, ive got a problem with orders, when i put an order into one PC, it show 10 ticks below or above at another PC. ive no idea what is wrong with that, but it is really confusing. it was working ok, till today, no clue what happened look at the screen http://www.sierrachart.com/image.php?l=1404924202155.png THIS ENTRY WAS PUT ON ANOTHER LAPTOP AT THE PRICE 16872. here it shows 16862 |
[2014-07-09 17:18:03] |
Next time you are flat the symbol, clear out the non-simulated Trade Activity Data for the symbol following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-10 11:21:15] |
mmm.. ok thanx.. but anyway, i think this is not the issue i was talking about the thing is quite simple. i dont do replay. i trade life. i use two laptops with the same markets, the interface is slightly different on each, but the markets are the same. when i put an entry order on YM market on the laptop A at the price lets say 16780, it shows on the laptop B at the price 16790. but only sometimes, sometimes it shows the same entry price at both pretty weird |
[2014-07-10 11:40:32] |
Do you see the same Trade Service Average Price for the symbol in Trade >> Trade Orders and Positions >> Positions on each copy of Sierra Chart?
[2014-07-10 11:43:37] |
Also, refer to the documentation here about how the Position Average Price is determined: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-11 16:08:13] |
i dont know why, but it all works fine now, without doing nothing..
