Date/Time: Wed, 27 Nov 2024 14:45:59 +0000
Trade fill times off
View Count: 239
[2023-07-28 20:42:00]
LF4801 - Posts: 1
I'm trying to export my trades to a journal, but the fill times are off by seven hours. This was not a problem until I adjusted my session times for 8:30:00 to 15:59:59 intraday and 16:59:59 to 8:29:59 for the evening session and selected yes to use evening session. I am on Chicago time. This is the time zone for all my charts as well as in common settings. What did I do to throw my fill times off? I attached an image of my trade activity log
imageScreenshot 2023-07-28 153953.png / V - Attached On 2023-07-28 20:40:39 UTC - Size: 43.81 KB - 66 views
[2023-07-28 21:04:55]
John - SC Support - Posts: 36315
There are two methods to export the Trade Activity Log information.
1) File >> Save Log As
- This will display the time exactly as it was shown in the Trade Activity Log. Refer to the information here:
Trade Activity Log: Saving to a Text File
2) File >> Export
- This will display the time as it is in UTC. Refer to the information here:
Trade Activity Log: Importing and Exporting Data
Which one you use will depend on whether you will want to import the information back into Sierra Chart (in which case you need to use the "Export" option), and how you want to view the times.
