Date/Time: Wed, 27 Nov 2024 14:24:50 +0000
Disconnect Live Account from Sierra Chart
View Count: 340
[2023-07-28 18:45:17] |
Yon - Posts: 2 |
Is it possible to stop using sierra chart to trade and revert back to broker platform and freely switch between?
[2023-07-28 19:30:32] |
John - SC Support - Posts: 36310 |
We are confused by your question, as the answer is "yes, of course" as this is your choice on how you use the system. So we are wondering if we are not understanding what you are asking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-29 12:14:36] |
Yon - Posts: 2 |
How to switch between sierra and broker platform? I can only place trades on sierra platform. I would like to switch back to broker platform to place trades.
[2023-07-31 13:51:30] |
We can not answer that question - you are asking how to use the broker platform. You need to ask your broker that question. In Sierra Chart, just keep the system in Simulation mode and there is nothing else you need to do. If you are using the Teton Order Routing Service, then you can not use that with any other platform. You would have to change order routing services in order to be able to use the broker platform. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-01 12:29:03] |
Sierra_Chart Engineering - Posts: 17194 |
In the case of when using Teton order routing, orders can only be submitted through Sierra Chart or the web-based trading panel: Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
