Date/Time: Wed, 27 Nov 2024 15:36:33 +0000
Using SC as Charting Provider
View Count: 228
[2023-07-28 15:34:49]
edgarlemos - Posts: 5
Good day,
I'm talking with AMP to open a brokerage account.
I intend to use either TT as an execution platform or perhaps Jigsaw.
I want to use SC as a charting only platform and I intend to use Package 11 and get data for CME bundle and also Eurex.
Since AMP can't answer to me how much I'd have to pay you, could you help me on this?
They said I need to pay them a Second Login and everything else would have to be with you.
How much would this cost me with you?
Thank you for your time
[2023-07-28 15:41:30]
John - SC Support - Posts: 36315
To begin with, you would need to be on one of the "Integrated Packages". You will find the information and cost for the packages at the following link:
Description of Service Packages and Pricing: Integrated Packages
You can also cut down the cost of the package by purchasing multiple months up front. Refer to the table here:
Description of Service Packages and Pricing: Multiple Month Purchase Discount
The cost for the EUREX data is $25.00 per month.
The CME Group has a number of options, so it depends on what exchanges you need and whether you need Market Depth data or not. You will find the list of exchanges and their monthly cost at the following link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
Due to the CME Group rule that you have to have a live, funded, futures trading account in order to qualify for the non-professional exchange fees, you will need to connect your Sierra Chart at least once a month to your AMP account.
Most likely you are being setup with CQG for your order routing with AMP. If this is the case, then follow the instructions at the following link to connect to that CQG account at least once a month:
CQG Trading Platform Service: Setup Instructions
For more information on connecting once a month, refer to the following:
