Date/Time: Wed, 27 Nov 2024 15:42:30 +0000
is there a study that would calculate the slope of VWAP?
View Count: 595
[2023-07-28 14:38:54]
coachted - Posts: 329
[2023-07-28 14:48:52]
User431178 - Posts: 544
Study Angle
[2023-07-28 15:12:14]
John - SC Support - Posts: 36315
There is also the "Linear Regression Slope" study. Refer to the following:
Linear Regressive Slope
And you can always calculate it yourself (Slope = Rise/Run) by using the Spreadsheet Formula and using a formula such as the following:
=(ID1.SG1 - ID1.SG1[-5]) / 5
Where ID1.SG1 is the VWAP value current bar and [-5] says to get the VWAP from 5 bars previous. Since you are dealing in Number of Bars as the run, you just divide by the number of bars of separation (5 in this case).
