Date/Time: Fri, 13 Nov 2026 09:47:57 +0000
[Programming Help] - ACSIL Volume By Price
View Count: 8934
| [2023-07-28 09:39:33] |
| vddfollow - Posts: 20 |
Dear all, Where can I access Volume By Price .cpp file ? I would like to make an ACSIL custom study based on the SC VBP Study ? How can I proceed ? Regards, J |
| [2023-07-28 12:42:52] |
| User431178 - Posts: 910 |
You can't, it is not available. How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available VAP data is available though, so nothing to stop you making your own version. ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars |
| [2023-07-28 13:06:03] |
| JohnR - User831573 - Posts: 340 |
J, I believe the source to that is not available. But, there is source and some docs that shows how to access the B/A volumes at each price level, I used this as a starting point to create custom code. Programmatically Accessing Volume at Price Data Volume By Price Study: Programmatically Accessing Volume at Price Data Then in Studies8.cpp there is an example that accesses the arrays of B/A members at each level /*===================================================================== Volume At Price array test. ----------------------------------------------------------------------------*/ SCSFExport scsf_VolumeAtPriceArrayTest(SCStudyInterfaceRef sc) Below is some of my code s_VolumeAtPriceV2* p_VolumeAtPrice = nullptr; int JOR_BarHighBidVol = 0; int JOR_BarLowBidVol = 0; int JOR_BarHighAskVol = 0; int JOR_BarLowAskVol = 0; // Now get the Bid & Ask Trade Volumes for the High and Low of the bar // Get the # of price levels - remember array start @ zero - so subtract 1 from count int JOR_BarPriceLevels = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index) - 1; // zero array is lowest price level if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, 0, &p_VolumeAtPrice)) return; JOR_BarLowBidVol = p_VolumeAtPrice->BidVolume; JOR_BarLowAskVol = p_VolumeAtPrice->AskVolume; // Highest price level in last array element if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, JOR_BarPriceLevels, &p_VolumeAtPrice)) return; JOR_BarHighBidVol = p_VolumeAtPrice->BidVolume; JOR_BarHighAskVol = p_VolumeAtPrice->AskVolume; Hope this helps, JohnR Date Time Of Last Edit: 2023-07-28 13:36:07
