Date/Time: Wed, 27 Nov 2024 15:42:47 +0000
Bid Ask Volume Bars
View Count: 317
[2023-07-27 16:05:32]
Le Dharma - Posts: 73
Is there a method to display Bid Volume and Ask volume, as a positive bar on the positive side of zero?
I can place Bid volume over ask volume, and so I will see both bars, if bid volume is lower than ask.
And if ask volume is lower, and bid volume is higher, then all I will see is bid volume. :/
Has Sierra made a Bid and Ask volume tool, that shows both bid and ask on each bar where all bars are above zero?
[2023-07-27 19:30:35]
John - SC Support - Posts: 36315
There is not a tool that does this the way you want.
What you can do is use the "Bid Volume vs. Ask Volume" study and set the "Width" of the Ask Volume Subgraph to be wider than what the Bid Volume Subgraph is set to. This way you will be able to see it even if the Ask Volume is less than the Bid Volume.
Refer to the following:
Chart Studies: Subgraphs Tab >> Line Width
