Date/Time: Wed, 27 Nov 2024 15:40:09 +0000
do not see any live data
View Count: 335
[2023-07-27 12:46:40]
User539180 - Posts: 7
hello i made payment of 65 dollars and i dont see any live data chart and no market depth
[2023-07-27 12:46:47]
Sierra_Chart Engineering - Posts: 17195
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-07-27 12:56:00]
Ok I did all that still delayed data for some reason
imageimage.jpg / V - Attached On 2023-07-27 12:55:36 UTC - Size: 3.09 MB - 81 views
[2023-07-27 13:18:55]
John - SC Support - Posts: 36315
We need to see your message log by following these instructions:
[2023-07-27 14:03:21]
Denali Data Feed | Failed connections: 211 | 2023-07-27 09:54:53.477
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:54:53.477
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:54:53.477
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:54:53.478
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:54:53.478
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:54:53.478
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:54:53.508
DTC Client socket (1) | Closed. | 2023-07-27 09:54:53.508
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 | 2023-07-27 09:55:23.482
DTC Client socket (1) | Creating socket. | 2023-07-27 09:55:23.484
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:55:23.484
DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-07-27 09:55:23.484
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:55:23.524
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:55:23.524
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:55:23.524
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:55:23.576
Denali Data Feed | Sending logon request message. | 2023-07-27 09:55:23.576
Denali Data Feed | Received logon response. | 2023-07-27 09:55:24.294
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:55:24.294
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:55:24.294
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:55:24.294
Denali Data Feed | Failed connections: 212 | 2023-07-27 09:55:24.294
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:55:24.294
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:55:24.295
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:55:24.295
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:55:24.295
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:55:24.295
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:55:24.324
DTC Client socket (1) | Closed. | 2023-07-27 09:55:24.324
The message log has been sent to support. | 2023-07-27 09:55:47.083 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2023-07-27 09:55:47.092
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0 | 2023-07-27 09:55:47.092
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2023-07-27 09:55:47.092
The Message Log was sent. Result: Message Log received. | 2023-07-27 09:55:48.454 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2023-07-27 09:55:48.708
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:55:48.709
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-07-27 09:55:48.851
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-07-27 09:55:48.851
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-07-27 09:55:54.309
DTC Client socket (1) | Creating socket. | 2023-07-27 09:55:54.310
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:55:54.311
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-07-27 09:55:54.311
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:55:54.345
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:55:54.345
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:55:54.345
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:55:54.409
Denali Data Feed | Sending logon request message. | 2023-07-27 09:55:54.409
Denali Data Feed | Received logon response. | 2023-07-27 09:55:55.129
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:55:55.129
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:55:55.129
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:55:55.129
Denali Data Feed | Failed connections: 213 | 2023-07-27 09:55:55.129
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:55:55.129
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:55:55.130
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:55:55.130
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:55:55.130
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:55:55.130
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:55:55.163
DTC Client socket (1) | Closed. | 2023-07-27 09:55:55.163
Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 10048 | 2023-07-27 09:56:25.131
DTC Client socket (1) | Creating socket. | 2023-07-27 09:56:25.133
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:56:25.133
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-07-27 09:56:25.134
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:56:25.218
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:56:25.218
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:56:25.218
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:56:25.307
Denali Data Feed | Sending logon request message. | 2023-07-27 09:56:25.307
Denali Data Feed | Received logon response. | 2023-07-27 09:56:25.401
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:56:25.401
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:56:25.401
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-07-27 09:56:25.401
Denali Data Feed | Failed connections: 214 | 2023-07-27 09:56:25.401
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:56:25.401
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:56:25.402
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:56:25.402
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-07-27 09:56:25.402
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:56:25.402
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:56:25.480
DTC Client socket (1) | Closed. | 2023-07-27 09:56:25.481
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 443 | 2023-07-27 09:56:27.403
DTC Client socket (1) | Creating socket. | 2023-07-27 09:56:27.404
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:56:27.404
DTC Client socket (1) | Connecting to IP: 142.215.17.187. | 2023-07-27 09:56:27.404
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:56:27.437
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:56:27.437
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:56:27.437
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:56:27.507
Denali Data Feed | Sending logon request message. | 2023-07-27 09:56:27.507
Denali Data Feed | Received logon response. | 2023-07-27 09:56:28.210
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:56:28.210
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:56:28.210
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:56:28.210
Denali Data Feed | Failed connections: 215 | 2023-07-27 09:56:28.210
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:56:28.210
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:56:28.211
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:56:28.211
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:56:28.212
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:56:28.212
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:56:28.252
DTC Client socket (1) | Closed. | 2023-07-27 09:56:28.253
Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-07-27 09:56:58.212
DTC Client socket (2) | Creating socket. | 2023-07-27 09:56:58.213
DTC Client socket (2) | New receive buffer size: 0 | 2023-07-27 09:56:58.213
DTC Client socket (2) | Connecting to IP: 142.215.17.188. | 2023-07-27 09:56:58.213
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:56:58.244
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:56:58.244
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:56:58.245
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:56:58.287
Denali Data Feed | Sending logon request message. | 2023-07-27 09:56:58.287
Denali Data Feed | Received logon response. | 2023-07-27 09:56:59.005
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:56:59.005
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:56:59.005
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:56:59.005
Denali Data Feed | Failed connections: 216 | 2023-07-27 09:56:59.005
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:56:59.005
DTC Client socket (2) | CloseSocket call. | 2023-07-27 09:56:59.006
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:56:59.006
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:56:59.006
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:56:59.007
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-07-27 09:56:59.038
DTC Client socket (2) | Closed. | 2023-07-27 09:56:59.038
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-07-27 09:57:29.002
DTC Client socket (1) | Creating socket. | 2023-07-27 09:57:29.024
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:57:29.024
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-07-27 09:57:29.024
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:57:29.056
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:57:29.056
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:57:29.056
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:57:29.117
Denali Data Feed | Sending logon request message. | 2023-07-27 09:57:29.117
Denali Data Feed | Received logon response. | 2023-07-27 09:57:29.826
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:57:29.826
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:57:29.826
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:57:29.826
Denali Data Feed | Failed connections: 217 | 2023-07-27 09:57:29.826
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:57:29.826
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:57:29.827
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:57:29.827
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:57:29.828
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:57:29.828
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:57:29.861
DTC Client socket (1) | Closed. | 2023-07-27 09:57:29.861
Denali Data Feed | Connecting to the server ds23.sierracharts.com. Port 10048 | 2023-07-27 09:57:59.830
DTC Client socket (1) | Creating socket. | 2023-07-27 09:57:59.832
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:57:59.832
DTC Client socket (1) | Connecting to IP: 142.215.17.190. | 2023-07-27 09:57:59.832
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:57:59.866
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:57:59.866
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:57:59.866
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:57:59.951
Denali Data Feed | Sending logon request message. | 2023-07-27 09:57:59.951
Denali Data Feed | Received logon response. | 2023-07-27 09:58:00.670
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:58:00.670
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:58:00.670
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:58:00.670
Denali Data Feed | Failed connections: 218 | 2023-07-27 09:58:00.670
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:58:00.670
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:58:00.671
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:58:00.671
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:58:00.671
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:58:00.671
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:58:00.701
DTC Client socket (1) | Closed. | 2023-07-27 09:58:00.701
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-07-27 09:58:30.672
DTC Client socket (1) | Creating socket. | 2023-07-27 09:58:30.692
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:58:30.692
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-07-27 09:58:30.692
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:58:30.726
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:58:30.726
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:58:30.726
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:58:30.785
Denali Data Feed | Sending logon request message. | 2023-07-27 09:58:30.785
Denali Data Feed | Received logon response. | 2023-07-27 09:58:31.521
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:58:31.521
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:58:31.521
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:58:31.521
Denali Data Feed | Failed connections: 219 | 2023-07-27 09:58:31.521
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:58:31.521
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:58:31.522
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:58:31.522
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:58:31.522
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:58:31.522
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:58:31.551
DTC Client socket (1) | Closed. | 2023-07-27 09:58:31.552
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-07-27 09:59:01.521
DTC Client socket (1) | Creating socket. | 2023-07-27 09:59:01.541
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:59:01.541
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-07-27 09:59:01.541
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:59:01.572
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:59:01.572
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:59:01.572
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:59:01.617
Denali Data Feed | Sending logon request message. | 2023-07-27 09:59:01.617
Denali Data Feed | Received logon response. | 2023-07-27 09:59:02.355
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:59:02.355
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:59:02.355
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:59:02.355
Denali Data Feed | Failed connections: 220 | 2023-07-27 09:59:02.355
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:59:02.355
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:59:02.356
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:59:02.356
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:59:02.356
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:59:02.356
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:59:02.385
DTC Client socket (1) | Closed. | 2023-07-27 09:59:02.385
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 | 2023-07-27 09:59:32.351
DTC Client socket (1) | Creating socket. | 2023-07-27 09:59:32.359
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 09:59:32.359
DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-07-27 09:59:32.360
Denali Data Feed | Network connection to server complete. | 2023-07-27 09:59:32.391
Denali Data Feed | Starting socket receive thread. | 2023-07-27 09:59:32.391
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 09:59:32.391
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 09:59:32.431
Denali Data Feed | Sending logon request message. | 2023-07-27 09:59:32.431
Denali Data Feed | Received logon response. | 2023-07-27 09:59:33.150
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 09:59:33.150
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 09:59:33.150
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 09:59:33.150
Denali Data Feed | Failed connections: 221 | 2023-07-27 09:59:33.150
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 09:59:33.150
DTC Client socket (1) | CloseSocket call. | 2023-07-27 09:59:33.151
Denali Data Feed | Disconnected from the server. | 2023-07-27 09:59:33.151
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 09:59:33.151
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 09:59:33.152
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 09:59:33.185
DTC Client socket (1) | Closed. | 2023-07-27 09:59:33.185
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2023-07-27 10:00:03.147
DTC Client socket (1) | Creating socket. | 2023-07-27 10:00:03.169
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:00:03.169
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-07-27 10:00:03.169
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:00:03.202
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:00:03.202
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:00:03.202
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:00:03.247
Denali Data Feed | Sending logon request message. | 2023-07-27 10:00:03.247
Denali Data Feed | Received logon response. | 2023-07-27 10:00:03.981
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 10:00:03.981
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 10:00:03.981
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 10:00:03.981
Denali Data Feed | Failed connections: 222 | 2023-07-27 10:00:03.981
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 10:00:03.981
DTC Client socket (1) | CloseSocket call. | 2023-07-27 10:00:03.982
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:00:03.982
Denali Data Feed | Disconnected from the server. | 2023-07-27 10:00:03.982
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 10:00:03.982
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 10:00:04.013
DTC Client socket (1) | Closed. | 2023-07-27 10:00:04.013
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2023-07-27 10:00:11.982
The message log has been sent to support. | 2023-07-27 10:00:11.982 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | New receive buffer size: 0 | 2023-07-27 10:00:11.982
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 95.216.233.104. | 2023-07-27 10:00:11.982
The Message Log was sent. Result: Message Log received. | 2023-07-27 10:00:13.398 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | CloseSocket call. | 2023-07-27 10:00:13.647
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:00:13.647
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2023-07-27 10:00:13.789
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2023-07-27 10:00:13.790
Denali Data Feed | Connecting to the server ds13.sierracharts.com. Port 443 | 2023-07-27 10:00:33.987
DTC Client socket (1) | Creating socket. | 2023-07-27 10:00:33.990
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:00:33.990
DTC Client socket (1) | Connecting to IP: 162.251.232.244. | 2023-07-27 10:00:33.990
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:00:34.071
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:00:34.071
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:00:34.071
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:00:34.156
Denali Data Feed | Sending logon request message. | 2023-07-27 10:00:34.156
Denali Data Feed | Received logon response. | 2023-07-27 10:00:34.251
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 10:00:34.251
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 10:00:34.251
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-07-27 10:00:34.251
Denali Data Feed | Failed connections: 223 | 2023-07-27 10:00:34.251
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 10:00:34.251
DTC Client socket (1) | CloseSocket call. | 2023-07-27 10:00:34.253
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:00:34.253
Denali Data Feed | Disconnected from the server. | 2023-07-27 10:00:34.253
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-07-27 10:00:34.253
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 10:00:34.332
DTC Client socket (1) | Closed. | 2023-07-27 10:00:34.332
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10048 | 2023-07-27 10:00:36.248
DTC Client socket (1) | Creating socket. | 2023-07-27 10:00:36.250
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:00:36.250
DTC Client socket (1) | Connecting to IP: 142.215.17.187. | 2023-07-27 10:00:36.250
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:00:36.281
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:00:36.281
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:00:36.281
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:00:36.333
Denali Data Feed | Sending logon request message. | 2023-07-27 10:00:36.333
Denali Data Feed | Received logon response. | 2023-07-27 10:00:37.060
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 10:00:37.060
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 10:00:37.060
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 10:00:37.060
Denali Data Feed | Failed connections: 224 | 2023-07-27 10:00:37.060
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 10:00:37.060
DTC Client socket (1) | CloseSocket call. | 2023-07-27 10:00:37.061
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:00:37.061
Denali Data Feed | Disconnected from the server. | 2023-07-27 10:00:37.061
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 10:00:37.061
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 10:00:37.091
DTC Client socket (1) | Closed. | 2023-07-27 10:00:37.091
Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048 | 2023-07-27 10:01:07.062
DTC Client socket (1) | Creating socket. | 2023-07-27 10:01:07.063
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:01:07.063
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-07-27 10:01:07.063
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:01:07.094
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:01:07.094
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:01:07.095
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:01:07.142
Denali Data Feed | Sending logon request message. | 2023-07-27 10:01:07.142
Denali Data Feed | Received logon response. | 2023-07-27 10:01:07.908
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 10:01:07.908
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 10:01:07.908
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 10:01:07.908
Denali Data Feed | Failed connections: 225 | 2023-07-27 10:01:07.908
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 10:01:07.908
DTC Client socket (1) | CloseSocket call. | 2023-07-27 10:01:07.908
Denali Data Feed | Disconnected from the server. | 2023-07-27 10:01:07.908
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 10:01:07.908
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:01:07.908
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 10:01:07.938
DTC Client socket (1) | Closed. | 2023-07-27 10:01:07.939
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 | 2023-07-27 10:01:37.917
DTC Client socket (1) | Creating socket. | 2023-07-27 10:01:37.925
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:01:37.925
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-07-27 10:01:37.925
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:01:37.957
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:01:37.957
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:01:37.957
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:01:38.013
Denali Data Feed | Sending logon request message. | 2023-07-27 10:01:38.013
Denali Data Feed | Received logon response. | 2023-07-27 10:01:38.714
Denali Data Feed | Server Name: RealTime Server. | 2023-07-27 10:01:38.714
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-27 10:01:38.714
Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 10:01:38.714
Denali Data Feed | Failed connections: 226 | 2023-07-27 10:01:38.714
Denali Data Feed | Waiting for socket receive thread to end | 2023-07-27 10:01:38.714
DTC Client socket (1) | CloseSocket call. | 2023-07-27 10:01:38.714
Denali Data Feed | Disconnected from the server. | 2023-07-27 10:01:38.714
Denali Data Feed | Data feed disconnected. Will reconnect in 30 seconds. | 2023-07-27 10:01:38.715
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-27 10:01:38.715
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-27 10:01:38.744
DTC Client socket (1) | Closed. | 2023-07-27 10:01:38.744
Denali Data Feed | Connecting to the server ds23.sierracharts.com. Port 10048 | 2023-07-27 10:02:08.703
DTC Client socket (1) | Creating socket. | 2023-07-27 10:02:08.710
DTC Client socket (1) | New receive buffer size: 0 | 2023-07-27 10:02:08.710
DTC Client socket (1) | Connecting to IP: 142.215.17.190. | 2023-07-27 10:02:08.710
Denali Data Feed | Network connection to server complete. | 2023-07-27 10:02:08.741
Denali Data Feed | Starting socket receive thread. | 2023-07-27 10:02:08.741
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-27 10:02:08.741
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-27 10:02:08.790
Denali Data Feed | Sending logon request message. | 2023-07-27 10:02:08.790
Date Time Of Last Edit: 2023-07-27 20:58:29
[2023-07-27 17:46:37]
The following line in your log is the reason for the issue:
"Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2023-07-27 08:18:07.940"
This means that you are connected to the Denali Exchange Data Feed from two different computers at the same time. Refer to the information here:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
