Date/Time: Wed, 27 Nov 2024 15:50:36 +0000
Datafeed connection problems
View Count: 327
[2023-07-27 10:02:46] |
User973770 - Posts: 2 |
Dear Support Team, I have sent a copy of my message log via 'Send for Analysis'. The reason is because overnight my datafeed stopped updating. To catch up all the data I had to disconnect from the datafeed and then reconnect. Any guidance you can provide would be greatly appreciated. Thanks |
[2023-07-27 10:37:50] |
Sierra_Chart Engineering - Posts: 17195 |
After the reconnect are you still having an issue?
[2023-07-27 21:02:35] |
No so far today. However it happened overnight last night, so I will see if it happens again tonight. Obviously with studies running 24h per day such behaviour isnt ideal so I wondered whether you'd be able to diagnose the issue from the log.
[2023-07-27 21:22:31] |
John - SC Support - Posts: 36316 |
It sounds like the issue you had was related to the following: Denali Data Feed Exchange Authorization Issue For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
