Date/Time: Wed, 27 Nov 2024 16:48:29 +0000
[Programming Help] - Spreadsheet formula array input syntax for MAX()
View Count: 319
[2023-07-26 20:54:01] |
User562383 - Posts: 10 |
Is there a way to input an array into a spreadsheet formula function? For example, to calculate the highest high over the last 5 bars (I know there's a prebuilt study this is just an example) I can use MAX(ID0.SG2[0],ID0.SG2[-1],ID0.SG2[-2],ID0.SG2[-3],ID0.SG2[-4]) But can this be rewritten as an array? Eg something like MAX(ID0.SG2[0]:ID0.SG2[-5]) I know this can easily be done in a spreadsheet study with the @ syntax, I am specifically asking about the spreadsheet formula bracket[] syntax. |
[2023-07-26 20:56:47] |
John - SC Support - Posts: 36322 |
The Spreadsheet Formula does not support the Range syntax like the Spreadsheet. As you state, it would have to be done by specifying each individual item.
