Date/Time: Wed, 27 Nov 2024 16:36:54 +0000
Modify Volume by Price multiplier by pressing a Control Bar button?
View Count: 256
[2023-07-26 20:17:45] |
funbun - Posts: 90 |
Or even better, a keyboard shortcut. Couldn't find it on the Control Bar menu. I trade equities and I constantly need to change the multiplier according to volatility. Changing it manually is becoming very tedious... |
[2023-07-26 20:55:43] |
John - SC Support - Posts: 36322 |
This is not available directly within Sierra Chart. You can create a custom study that will give you the capability you want. Refer to the following variable in particular: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceMultiplier For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
