Date/Time: Wed, 27 Nov 2024 15:36:25 +0000
Blank Chart
View Count: 335
[2023-07-26 13:48:09] |
John Michael Arenga - Posts: 2 |
I just started a fully activate a 15 days trial. But I cannot see any data in some of the chart, I can see the data in MES-CME but not in ES-CME. How can I fix it? Thank you. Date Time Of Last Edit: 2023-07-26 14:51:28
[2023-07-26 16:10:03] |
John - SC Support - Posts: 36315 |
You had not activated your trial, therefore you were limited on what data you could view and how much. Refer to the following for more information: Sierra Chart Trial Account We have activated the trial for your account, so you now have access to more data, including the ES. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-27 01:49:21] |
I got it. Thanks. The Data in Free Trial, is it delayed or a real time data?
[2023-07-27 09:20:05] |
Sierra_Chart Engineering - Posts: 17195 |
It depends upon the symbol. Refer to: Real-Time Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
