Date/Time: Wed, 27 Nov 2024 15:41:38 +0000
calculate price between last to last high/bottom
View Count: 294
[2023-07-26 12:26:15] |
User278398 - Posts: 291 |
hello, there is a study/formula to calculate the price from last to last high/bottom? in the example i want to get the value -0.66 (266.34-267) regards |
[2023-07-26 15:54:52] |
John - SC Support - Posts: 36315 |
Refer to the following: High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-27 07:32:52] |
i need to put specific range time in the parameters, for this study. (for exa: from: 9:45:00 to 10:50:00) but i need the high/low of the last time (for exa: the last 60 min (relative to last price)) regards |
[2023-07-27 13:32:54] |
To do this you would need to use the Spreadsheet Study and use the MAX() and MIN() functions to find the high and low. Refer to the following for the MAX() function: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#MAX_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
