Date/Time: Mon, 14 Sep 2026 12:42:57 +0000
fan-made manual-ish?
View Count: 1303
| [2014-07-09 12:52:56] |
| User64687 - Posts: 6 |
Love this software, can't understand how bad this manual is written... I've used so much different software before, but here I can't even get trading out of simulation mode (after hours). Isn't there any other manual/howto on how to connect SC with my exchange? Date Time Of Last Edit: 2014-07-09 13:12:18
| [2014-07-10 05:39:42] |
What specific exchange are you referring to? And what is the particular problem you are having when using Trade Simulation Mode. This is not clear enough for us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-07-10 11:59:10] |
Now that I read my post back, I see how frustrated I must've been, sorry for a post like that, here's the problem: I use bitfinex, and I am trying to get the trade functions on SC to work for this exchange. First I unmark the "simulation mode on" option. The option "connect to data feed", this seems to be disabled, so I am already connected to the data feed. Now I get the trading screen, but I have in no way connected to bitfinex. I thought I saw a page somewhere saying SC doesn't use API anymore, how do I connect to bitfinex then? Thanks for your response |
| [2014-07-10 16:28:55] |
At this time, Sierra Chart does not support trading through bitfinex. We intend to add trading support . We will try to get this done soon. But probably not until next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
