Date/Time: Fri, 22 Nov 2024 08:17:59 +0000
Using IB Advisor Chart trading
View Count: 1832
[2013-05-03 00:32:01] |
User23815 - Posts: 210 |
New user. I am setting up to trade directly from SC Chart Trader to IB Advisor Account. If I want the attached orders from SC to be in control, do I uncheck the box in More IB Settings that says Use IB Managed OCO and Bracket Orders? If I have stops and targets set in Trader Work Station at IB, do I need to disable or remove them in order for them not to intervene with the SC trade parameters? I entered the sub accounts in the Positions box, nothing in the Order Account box. When I place the trade, all orders show, Limit entry, stop-loss and target. Once filled the entry order, with the running p&l disappears. It doesn't do this in regular non-advisor account trading. What do I need to set correctly in order for the entry line with running P&L to continue showing after entry and TWS sends the units to the sub accounts? Thanks |
[2013-05-03 01:55:59] |
What exactly do you mean by " SC to be in control"? If I have stops and targets set in Trader Work Station at IB, do I need to disable or remove them in order for them not to intervene with the SC trade parameters? We would not think so. But we do not know the full context of the question. This is too vague. You need to use the independent Position tracking feature: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#UsingIndependentInternalPositions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
