Date/Time: Wed, 27 Nov 2024 16:48:33 +0000
How to change a parameter in a study on all charts?
View Count: 278
[2023-07-26 06:59:56] |
Piotr Grzegorzek - Posts: 21 |
I use a study on all charts and I want to change one color in this study on all charts at once. There would be a button needed "Apply to all study's on all charts and chartbooks" Is it possible? |
[2023-07-26 14:12:28] |
John - SC Support - Posts: 36322 |
The way to do this is through "Chart Linking" and setting the option for "Studies". The only issue with this is that it is going to link all of the studies, so if the studies are different on the charts, then this will not work. In which case you have to modify each one separately. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
