Date/Time: Wed, 27 Nov 2024 15:50:54 +0000
Automatic screen adjusting
View Count: 301
[2023-07-25 18:39:46]
User746875 - Posts: 30
I'm trying to get both my Footprint and DOM charts to automatically re-center instead of me having to manually re-center them. I right-click on either window and I see options I believe would help. I see the "Scale Range: User Defined" option checked, but I think I would need the "Scale Range: Automatic" option instead. So, I click on that but the "Scale Range: User Defined" option stays checked. Am I doing something incorrect? I can't seem to select the "Scale Range: Automatic" option.
imageClipboard01.jpg / V - Attached On 2023-07-25 18:39:30 UTC - Size: 23.87 KB - 83 views
[2023-07-26 13:23:38]
John - SC Support - Posts: 36316
On a Trading DOM, you can not use the "Automatic" scaling mode. That is why it keeps changing back on you.
If you want the Trading DOM to always stay centered, that is the last traded price will always be displayed in the center, then open the Scale Settings for that window and set the "Constant Range Scale Mode" to "Re-center to Last Bar on Every Update". Refer to the following:
Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Bar On Every Update
There are other options that you may prefer, so if the above is not exactly what you want, then look through the other options to see if one of them may be more of what you want.
[2023-07-27 17:18:20]
Thank you. That resolved my problem!
