Date/Time: Wed, 27 Nov 2024 16:48:56 +0000
Which version for CQG Data support
View Count: 239
[2023-07-25 15:20:02]
User459170 - Posts: 262
I use CQG Data, but I'm still using version 2387 Which version should I be on to be able to use CQG Data. Thanks very much.
Date Time Of Last Edit: 2023-07-25 15:21:20
[2023-07-25 16:13:56]
John - SC Support - Posts: 36322
version 2393 is the latest version that has support for CQG data for the CME Group and EUREX. Any version later than that (2394 and up) will not be able to bring in this data.
If you are asking about Packages - you need to be on one of the "Integrated" packages in order to be able to connect to trading services and get real-time data. Refer to the following:
Description of Service Packages and Pricing: Integrated Packages
