Date/Time: Wed, 27 Nov 2024 15:40:37 +0000
SC download intraday data very slow since version 2524
View Count: 318
[2023-07-25 09:36:41]
User665858 - Posts: 3
Dear Support,
SC download runs very slow using Denali Data Feed starting from version 2524.
I tried identical configs also with earlier (2490.2500,2510,2520,2523) and later version (2524,2525,2526)
Simple Chartbook with e.g. F.US.M2Kxxx and intraday 300 days takes on earlier versions aprx. 8 minutes to complete
Since 2524 it runs extremely slow and takes several hours to complete.
AMPFutures
CQG with Denali Data
Srv.Setting: Intraday storage: 1 Tick
Chart: Intraday 1m (300 days)
Chart: Symbol cont. contract: Volume based rollover, back adjusted
Let me know if you have a cause / fix for that and if I can provide more information to help you fix that issue.
Thanks a lot
BR // Jens
attachmentChartbook1.Cht - Attached On 2023-07-25 09:31:54 UTC - Size: 3.04 KB - 154 views
[2023-07-25 11:22:25]
Sierra_Chart Engineering - Posts: 17195
We know this is the case when using Wine and we are working on a solution to this. We should have this ready this afternoon.
Date Time Of Last Edit: 2023-07-25 11:22:55
[2023-07-27 18:24:10]
VLiviu - Posts: 223
@SC I saw you published a resolution but SC is still slow, very, waiting for the charts 1h already....
[2023-07-27 18:53:11]
As long as you followed the instructions, and you are using a single receive buffer, we cannot do any better.
Date Time Of Last Edit: 2023-07-27 18:53:19
[2023-07-27 19:21:17]
VLiviu - Posts: 223
Interesting is that I had moments with full speed than it dropped fast.
Anyways, thanks
