Date/Time: Wed, 27 Nov 2024 14:46:00 +0000
scsf_VerticalTimeLine study doesn't obey SetStudyVisibilityState() params
View Count: 285
[2023-07-25 01:41:44]
User275839 - Posts: 61
[Sierra Chart v.2517 64-bit, Revision 46446)
If a vertical time line is showing, calling SetStudyVisibilityState() with Visible = 0 will hide the vertical line, but leave the custom label showing.
The converse is true as well: when a vertical time line is hidden (using the Chart Studies dialog), calling SetStudyVisibilityState() with Visible = 1 will show the vertical time line, but the custom label fails to draw.
Showing/Hiding a vertical time line using the Chart Studies dialog yields the expected results.
Can this be fixed in a future update to the Sierra default studies suite?
Thank you!
[2023-07-25 18:50:46]
Sierra_Chart Engineering - Posts: 17195
Yes we will see how to solve this.
[2023-08-02 18:50:28]
After using this:
Recalculate the study being modified.
