Date/Time: Wed, 27 Nov 2024 16:31:08 +0000
looped Alert Sound
View Count: 240
[2023-07-24 16:20:09] |
ppoignot - Posts: 10 |
Hello, I have an audible alert for the RSI, but when it goes off it sometimes goes off in a loop for several minutes if the RSI regularly returns to the level. How can I set a limit? For example, a maximum of one identical audible alert per minute... ? RSI : =OR(SG1 > 85 , SG1 < 15) |
[2023-07-24 19:32:18] |
John - SC Support - Posts: 36322 |
The only way to control this would be to enable the option for "Alert Only Once per Bar". But depending on your bar period, this may not be exactly what you want. Refer to the following: Study/Chart Alerts And Scanning: Alert Only Once Per Bar If the above does not solve the issue, then you would have to use the Spreadsheet System/Alert, or create a custom study to do what you want. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
