Date/Time: Wed, 27 Nov 2024 16:42:23 +0000
RE: NQUS500LC-NQGI
View Count: 286
[2023-07-24 13:41:56]
User426308 - Posts: 18
What happened to the NQUS500LC-NQGI; it doesn't appear to be updating?
[2023-07-24 14:22:52]
John - SC Support - Posts: 36322
Check your Session Times. It looks like the default Session Times are set to 09:30 Central US, but it should be 08:30 and go through 15:00. If you set your Session Times for the full 24 hours of a day, you will see when this is being updated.
Refer to the following:
Chart Session Times
[2023-07-24 14:36:00]
My session times have not changed; everything was fine until this morning. The NQUSL-NQGI cranked up at the open but the NQUS500LC-NQGI is still not updating.
[2023-07-24 15:53:31]
Sierra_Chart Engineering - Posts: 17195
We do see a problem with this symbol on our side on one of the servers. It is resolved. Are you receiving data now?
[2023-07-24 15:56:44]
The updates just started at 11:50 AM, EST.
[2023-07-24 16:17:53]
We will be looking into why this issue has occurred. It is not yet known at this time.
Date Time Of Last Edit: 2023-07-24 16:18:10
