Date/Time: Wed, 27 Nov 2024 16:52:06 +0000
dax index data feed how to
View Count: 548
[2023-07-24 10:02:01] |
User277159 - Posts: 13 |
Hi, I have denali package 11 and im wondering how can i get the Dax index data it doesn't seem to be coming through or have found the right one, do i need another data feed? |
[2023-07-24 13:49:01] |
John - SC Support - Posts: 36323 |
You need to activate (and pay for) the EUREX exchange. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Just be aware that the exchanges are not pro-rated, so you will pay the full price for the exchange for the remainder of the month in which you activate the exchange, and then pay again on the first day of the following month for that month. In other words, since we are close to the end of this month, you may want to wait until the first day of next month to activate the exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-24 15:45:59] |
Sierra_Chart Engineering - Posts: 17195 |
If you want delayed EUREX data follow the instructions here: Delayed Exchange Data Feed Install another installation of Sierra Chart for that. Do you want real-time EUREX data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-24 17:37:37] |
Awesome, thanks very much for getting back to me, could i ask another question, im interested in the FTSE100 also, and that is the CFd data feed, am i able to try that aswell or do i have to pay for another data feed for that aswell? Many thanks in advance
[2023-07-24 20:05:09] |
If you are referring to the "UK100" CFD symbol, then the FXCM data for this is available at no extra charge. Just open a chart for this symbol - you will find the CFD symbols listed in the "File >> Find Symbol" window under the "CFD - FXCM" section.
