Date/Time: Wed, 27 Nov 2024 16:44:08 +0000
Study Overlay
View Count: 273
[2023-07-24 09:21:39] |
Federico Roveda - Posts: 34 |
Hi, I have a RTH-VWAP overlaid in my full session chart. The RTH-VWAP is calculated on a different chart (only with RTH session) with the same periodicity, i.e. 15r. However, I always have a ghost effect during the ETH session (see orange circle in the attachment), even if the RTH-VWAP should not be present. How can I fix it? Thanks |
2023-07-24_11-15-42.png / V - Attached On 2023-07-24 09:20:05 UTC - Size: 215.08 KB - 82 views |
[2023-07-24 13:45:58] |
John - SC Support - Posts: 36322 |
If that is still showing when the RTH-VWAP is not present, then this implies that it is coming from a different study. Duplicate the chart and remove the studies, one by one, until you find the culprit.
[2023-07-24 14:32:01] |
FYI - I sorted out by changing the 'Bar Time Matching Method' in 'Containing Match'. Thanks |
