Date/Time: Wed, 27 Nov 2024 16:54:44 +0000
Questions about chart setup.....
View Count: 365
[2023-07-24 03:17:35]
krypto101 - Posts: 33
Hi
I'm building a footprint chart composed of three columns and I'd like to know if there's a way to flip the profile histogram (column1) so it faces to the left.
I know its possible, I just don't see the setting for it.
2. I have a TPO chart which prints a new profile every hour. Is it possible to overlay a candlesticks chart or line graph on top of the TPO profiles?
also, can I add monthly volume profile on the TPO chart, when I try adding a volume profile, it automatically aligns with the TPO profiles instead!
I've added images- I'm not much of a reader so please don't send me to the documents page
Date Time Of Last Edit: 2023-07-24 03:18:47
image9879879786.png / V - Attached On 2023-07-24 03:16:32 UTC - Size: 129.75 KB - 68 views
image98798795.png / V - Attached On 2023-07-24 03:16:40 UTC - Size: 166.46 KB - 80 views
[2023-07-24 05:40:28]
User688525 - Posts: 258
For 1), have you selected "Right Aligned Ask Bid Difference Profile" in "Column 1 Background Type" within the Numbers Bars study settings?
For 2), I don't think this is possible as the TPO is a special kind of study. Sierra Chart Engineering (or someone else) can confirm.
For 3), when you add the VbP study, have you set "Set as Independent Volume Profile for TPO Chart" to "Yes" within the VbP study settings?
[2023-07-24 07:13:48]
Thank you for the response! Most of you you suggested worked for me, just need to find out if the candle stick can be overlayed on a TPO chart.
[2023-07-24 08:49:52]
Sierra_Chart Engineering - Posts: 17195
No a standard candlestick chart cannot be overlaid on a TPO Profile Chart. The horizontal scales are just not compatible.
