Date/Time: Wed, 27 Nov 2024 16:29:52 +0000
Color CandleSticks based on Fibonacci levels?
View Count: 242
[2023-07-24 01:05:45]
ameetmedi - Posts: 4
I was wondering if there is an existing study that lets you color the candlesticks as they moved through the Fibs levels from a Swing High to a Swing Low. Candlesticks that are bouncing in between the levels of 38.2, 50, 61.8 from a swing low would be yellow and only breaking above 61.8 would give a buy signal, From a swing high a candlestick breaking the 23.6 level would give a sell signal.
[2023-07-24 08:16:15]
Sierra_Chart Engineering - Posts: 17195
No, this is not supported but you could create this using ACSIL:
Advanced Custom Study Interface and Language (ACSIL)
To access data from Chart Drawings, refer to:
Using Drawing Tools From an Advanced Custom Study
