Date/Time: Wed, 27 Nov 2024 16:35:41 +0000
Datafeed possibilities
View Count: 242
[2023-07-23 20:15:17]
User345740 - Posts: 10
Good evening,
Is it possible to connect to an amp futures account to trade on CME but still be able to load the binance charts? Currently I'm using the CQG webapi, but I've read that its also better to use the Sierra Chart CME Tenton routing service, which I will try to activate soon.
I am just trying to achieve to trade on CME but still access all symbols that are available via the Sierra Chart datafeed. Is there a way to do this? I have been reading documentation all day and browsing the board but I cant find the answer to this.
Thanks in advance for your time.
Kind regards,
Regenetic
[2023-07-23 22:59:12]
Sierra_Chart Engineering - Posts: 17195
Yes this is supported. You will find the Binance symbols in File >> Find Symbol.
However, they are not listed for CQG. But you can easily set up another installation of Sierra Chart for this:
Using Multiple Data and Trading Services at the Same Time
Date Time Of Last Edit: 2023-07-23 22:59:39
