Date/Time: Wed, 27 Nov 2024 14:31:57 +0000
[Programming Help] - Contributed Advanced Custom Study
View Count: 372
[2023-07-23 19:02:15]
User352781 - Posts: 24
I was hoping to get help with one of the contributed custom studies that I'm using on Sierra chart.
I have been using it for the past few months and it seems to be working fine for my strategy.
I have been told at times Sierra chart might remove a custom study if it doesn't get updated or used.
If that is the case, I was wondering can I please have the Source code for the below custom study, so that I can save it incase it ever gets removed.
Thank you in advance.
Contributed Advanced Custom Study:
"JDT Trend catcher3"
[2023-07-24 13:13:40]
John - SC Support - Posts: 36313
All of the source code we have for the User Contributed Studies are are the following link:
User Contributed Advanced Custom Study System Source Code
That particular study is under the file named "jdtTrend.cpp"
[2023-07-30 21:39:46]
Hello John,
The "jdtTrend.cpp" when compiled, comes back with the below errors.
"None of the selected source files contains the SCDLLName() line at the top of the file. Refer to ACSIL documentation.
-- End of Build -- 17:26:51"
Is there a reason why the code is not updated in the System Source Code? Even though I'm using it through Contributed Custom Study"
There is has to be an updated Source code of "jdtTrend.CPP" somewhere where I can compile and save it for myself.
We are using it in the Custom Study, and it works fine, but for some reason the Source Code is not compiling.
Let me know what is it that I'm doing wrong.
Thank you,
[2023-07-30 22:20:31]
One more thing John,
Can you also look into this source code for me please? same issue "BricksTrend". When compiled comes back with errors.
Where can I find the updated versions of these Codes? or does sierra chart have a source code that does the same exact thing as BricksTrend, but maybe with a different name in the provided Studies list.
[2023-08-01 13:26:43]
Sierra_Chart Engineering - Posts: 17194
We really are not actively keeping these studies up-to-date if there is a new version. You may be best just to rely on your own searching, rather than us.
Date Time Of Last Edit: 2023-08-01 13:27:00
