Date/Time: Wed, 27 Nov 2024 16:39:15 +0000
SC crashing (High GPU) when trying to load 6 months of intraday tick data for MES
View Count: 263
[2023-07-23 11:53:52]
HerculesT41 - Posts: 12
I am using SC for close to 3 years and used chart reply in past.
I am using SC denali and using SC in trading evaluator mode.
I only have 3 cahrts (5/15/60 min) . I changed my 5 min chart "Days to download" to 180 to be able to replay last 6 months on 5 min chart. there are two issues
1) lot of tick data is missing from jan to april 2023
2) SC ALWAYS chrashes withhin 1 min of chartbook load. i can see GPU usage hopping to 100 and then to zero.
except for moving averages overlay from 60 min to 5 min, there is no other study in my chartbook.
i have otehr chartbooks with 5-20 days of intraday data and they all are working fine. only when i load chart replay chartbook with 180 days, system crashes.
any idea how i can fix this issue?
[2023-07-24 12:58:47]
John - SC Support - Posts: 36322
For issue 1, follow the instructions at the following link:
For issue 2, we do not know, as this should not occur. The first thing to always do in a situation like this is to update to the latest release to ensure that this is not something that has been already fixed. Follow these instructions to update:
If you still have an issue, then we need to know what kind of replay are you running, and for how many charts?
