Date/Time: Wed, 27 Nov 2024 16:33:38 +0000
Can't add any columns to DOM.
View Count: 325
[2023-07-23 01:37:39] |
User355599 - Posts: 1 |
I want to add columns to my DOM. I opened up my chart for NQU23, as well as the DOM that goes with it. I went to "Trade">>>"Customize Chart/Trade DOM Columns" and then added the columns I want. I then hit apply, but the columns did not show up on the DOM. I pressed okay and closed out as well, which also didn't work. Why won't the changes apply???
Screenshot (371).png / V - Attached On 2023-07-23 01:36:45 UTC - Size: 130.18 KB - 76 views |
[2023-07-24 12:51:33] |
John - SC Support - Posts: 36322 |
You are not opening the correct window. For the Trade DOM, you need to select "Trade >> Customize Chart/Trade DOM Columns" from the menus on the Trade DOM itself. Selecting it from the main Sierra Chart window only affects the attached chart.
