Date/Time: Wed, 27 Nov 2024 16:34:02 +0000
[User Discussion] - Display volume profile on right side footprint
View Count: 412
[2023-07-22 23:21:37] |
Bnisaih - Posts: 2 |
Hello, I'm trying to make the volume profile appear on the right of the chart like this style but I can't, I don't want column 2 and 3 because it hides part of the candle, and I don't want to use the outline either but a normal candle like this. I tried with the pullback column and it's very good but the problem is that it doesn't display the historical bar. |
Attachment Deleted. 356946238_655246586663548_3556063959040289746_n.jpg / V - Attached On 2023-07-22 23:20:25 UTC - Size: 197.19 KB - 136 views |
[2023-07-23 13:14:45] |
Sierra_Chart Engineering - Posts: 17195 |
If you are using the Numbers Bars study, you would need to using the second column and set the Background Type Input for that column to Volume Profile. A second column is necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-23 13:15:00
[2023-07-23 14:12:57] |
Yes I have already tried and the result is that the footprint number is moved to the left of the candle. If there was a way to move the volume profile a bit to the right? |
[2023-07-24 13:03:33] |
John - SC Support - Posts: 36322 |
Can you please give us an image of what you are seeing, as the use of multiple columns should not have any overlap.
