Date/Time: Thu, 17 Sep 2026 04:40:21 +0000
enabeling for socket client with IB. I am not able to connect to IB
View Count: 1337
[2014-07-08 12:46:19]
User10023 - Posts: 3
Software version: 1148 | 2014-07-08 08:40:50
Usage end date: 2015-04-09 | 2014-07-08 08:40:50
Enabled for: Advanced Features. | 2014-07-08 08:40:50
Enabled for: Advanced Features 2. | 2014-07-08 08:40:50
Enabled for: Sierra Chart Historical Data Service. | 2014-07-08 08:40:50
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-07-08 08:40:50
Active service: Interactive Brokers | 2014-07-08 08:40:50
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-07-08 08:40:50
2014-07-08 08:40:50 Local computer clock time | 2014-07-08 08:40:50
2014-07-08 12:40:50 GMT time | 2014-07-08 08:40:50
2014-07-08 08:40:50 Time zone adjusted time | 2014-07-08 08:40:50
Time difference to server time: 1 seconds. | 2014-07-08 08:40:50
Program path: C:\SierraChart\ | 2014-07-08 08:40:50
Data Files path: C:\SierraChart\Data\ | 2014-07-08 08:40:50
OS Version Number: 6.1 | 2014-07-08 08:40:50
Checking for new symbol settings for ib | 2014-07-08 08:40:50
Symbol settings are up-to-date for ib | 2014-07-08 08:40:51
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:40:55
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:40:56
Socket has been shutdown and closed. | 2014-07-08 08:40:56
Failed to connect to the data and trade server. | 2014-07-08 08:40:56
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:40:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:40:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:40:56
Disconnected from IB. | 2014-07-08 08:40:56
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:40:56
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:01
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:02
Socket has been shutdown and closed. | 2014-07-08 08:41:02
Failed to connect to the data and trade server. | 2014-07-08 08:41:02
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:02
Disconnected from IB. | 2014-07-08 08:41:02
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:02
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:07
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:08
Socket has been shutdown and closed. | 2014-07-08 08:41:08
Failed to connect to the data and trade server. | 2014-07-08 08:41:08
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:08
Disconnected from IB. | 2014-07-08 08:41:08
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:13
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:14
Socket has been shutdown and closed. | 2014-07-08 08:41:14
Failed to connect to the data and trade server. | 2014-07-08 08:41:14
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:14
Disconnected from IB. | 2014-07-08 08:41:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:14
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:19
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:20
Socket has been shutdown and closed. | 2014-07-08 08:41:20
Failed to connect to the data and trade server. | 2014-07-08 08:41:20
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:20
Disconnected from IB. | 2014-07-08 08:41:20
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:20
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:25
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:26
Socket has been shutdown and closed. | 2014-07-08 08:41:26
Failed to connect to the data and trade server. | 2014-07-08 08:41:26
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:26
Disconnected from IB. | 2014-07-08 08:41:26
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:26
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:31
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:32
Socket has been shutdown and closed. | 2014-07-08 08:41:32
Failed to connect to the data and trade server. | 2014-07-08 08:41:32
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:32
Disconnected from IB. | 2014-07-08 08:41:33
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:33
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:38
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:39
Socket has been shutdown and closed. | 2014-07-08 08:41:39
Failed to connect to the data and trade server. | 2014-07-08 08:41:39
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:39
Disconnected from IB. | 2014-07-08 08:41:39
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:39
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:44
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:45
Socket has been shutdown and closed. | 2014-07-08 08:41:45
Failed to connect to the data and trade server. | 2014-07-08 08:41:45
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:45
Disconnected from IB. | 2014-07-08 08:41:45
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:45
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:50
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:51
Socket has been shutdown and closed. | 2014-07-08 08:41:51
Failed to connect to the data and trade server. | 2014-07-08 08:41:51
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:51
Disconnected from IB. | 2014-07-08 08:41:51
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:51
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:41:56
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:41:57
Socket has been shutdown and closed. | 2014-07-08 08:41:57
Failed to connect to the data and trade server. | 2014-07-08 08:41:57
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:41:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:41:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:41:57
Disconnected from IB. | 2014-07-08 08:41:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:41:57
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:02
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:03
Socket has been shutdown and closed. | 2014-07-08 08:42:03
Failed to connect to the data and trade server. | 2014-07-08 08:42:03
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:03
Disconnected from IB. | 2014-07-08 08:42:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:03
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:08
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:09
Socket has been shutdown and closed. | 2014-07-08 08:42:09
Failed to connect to the data and trade server. | 2014-07-08 08:42:09
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:09
Disconnected from IB. | 2014-07-08 08:42:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:09
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:14
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:15
Socket has been shutdown and closed. | 2014-07-08 08:42:15
Failed to connect to the data and trade server. | 2014-07-08 08:42:15
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:15
Disconnected from IB. | 2014-07-08 08:42:15
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:15
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:20
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:21
Socket has been shutdown and closed. | 2014-07-08 08:42:21
Failed to connect to the data and trade server. | 2014-07-08 08:42:21
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:21
Disconnected from IB. | 2014-07-08 08:42:21
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:21
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:26
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:27
Socket has been shutdown and closed. | 2014-07-08 08:42:27
Failed to connect to the data and trade server. | 2014-07-08 08:42:27
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:27
Disconnected from IB. | 2014-07-08 08:42:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:27
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:32
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:33
Socket has been shutdown and closed. | 2014-07-08 08:42:33
Failed to connect to the data and trade server. | 2014-07-08 08:42:33
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:33
Disconnected from IB. | 2014-07-08 08:42:33
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:33
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:38
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:39
Socket has been shutdown and closed. | 2014-07-08 08:42:39
Failed to connect to the data and trade server. | 2014-07-08 08:42:39
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:39
Disconnected from IB. | 2014-07-08 08:42:39
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:39
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:44
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:45
Socket has been shutdown and closed. | 2014-07-08 08:42:45
Failed to connect to the data and trade server. | 2014-07-08 08:42:45
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:45
Disconnected from IB. | 2014-07-08 08:42:45
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:45
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:50
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:51
Socket has been shutdown and closed. | 2014-07-08 08:42:51
Failed to connect to the data and trade server. | 2014-07-08 08:42:51
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:51
Disconnected from IB. | 2014-07-08 08:42:51
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:51
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:42:56
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:42:57
Socket has been shutdown and closed. | 2014-07-08 08:42:57
Failed to connect to the data and trade server. | 2014-07-08 08:42:57
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:42:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:42:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:42:57
Disconnected from IB. | 2014-07-08 08:42:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:42:57
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:02
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:03
Socket has been shutdown and closed. | 2014-07-08 08:43:03
Failed to connect to the data and trade server. | 2014-07-08 08:43:03
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:03
Disconnected from IB. | 2014-07-08 08:43:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:03
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:08
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:09
Socket has been shutdown and closed. | 2014-07-08 08:43:09
Failed to connect to the data and trade server. | 2014-07-08 08:43:09
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:09
Disconnected from IB. | 2014-07-08 08:43:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:09
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:14
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:15
Socket has been shutdown and closed. | 2014-07-08 08:43:15
Failed to connect to the data and trade server. | 2014-07-08 08:43:15
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:15
Disconnected from IB. | 2014-07-08 08:43:15
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:15
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:20
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:21
Socket has been shutdown and closed. | 2014-07-08 08:43:21
Failed to connect to the data and trade server. | 2014-07-08 08:43:21
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:21
Disconnected from IB. | 2014-07-08 08:43:21
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:21
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:26
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:27
Socket has been shutdown and closed. | 2014-07-08 08:43:27
Failed to connect to the data and trade server. | 2014-07-08 08:43:27
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:27
Disconnected from IB. | 2014-07-08 08:43:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:27
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:32
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:33
Socket has been shutdown and closed. | 2014-07-08 08:43:33
Failed to connect to the data and trade server. | 2014-07-08 08:43:33
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:33
Disconnected from IB. | 2014-07-08 08:43:33
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:33
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:38
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:39
Socket has been shutdown and closed. | 2014-07-08 08:43:39
Failed to connect to the data and trade server. | 2014-07-08 08:43:39
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:39
Disconnected from IB. | 2014-07-08 08:43:39
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:39
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:44
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:45
Socket has been shutdown and closed. | 2014-07-08 08:43:45
Failed to connect to the data and trade server. | 2014-07-08 08:43:45
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:45
Disconnected from IB. | 2014-07-08 08:43:45
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:45
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-07-08 08:43:50
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-07-08 08:43:51
Socket has been shutdown and closed. | 2014-07-08 08:43:51
Failed to connect to the data and trade server. | 2014-07-08 08:43:51
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-07-08 08:43:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-08 08:43:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-08 08:43:51
Disconnected from IB. | 2014-07-08 08:43:51
Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-07-08 08:43:51
[2014-07-08 16:33:32]
There are a set of instructions that we have prepared that explain what to do in this case. Follow through the instructions at step 21 and 22 here:
http://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
