Date/Time: Wed, 27 Nov 2024 16:45:34 +0000
IBKR ATM options straddle symbols
View Count: 263
[2023-07-21 16:07:28] |
MatZer0 - Posts: 36 |
Hi, What symbol do I need to enter into the SC to chart combined options trades like straddles? I'm aware of the symbol name format required to chart single options from IBKR, but I couldn't information about combined trades symbols Let's say I want to chart 0 day SPY or SPX ATM straddle price. Is there a special symbol combination to chart such trades in Sierra Chart? Or do I have to put two different symbols and calculate the sum/difference from two charts? Is there any special way to specyfy the "ATM" strike as a wildcard, rather than manually typing a particular strike price? Thanks |
[2023-07-21 18:02:13] |
John - SC Support - Posts: 36322 |
You could always bring in additional data using the "Add Additional Symbol" and then Add/Subtract the charts using the "Bar Difference" and "Sum - Bar" studies (or the "Spreadsheet Formula - Bar" study). Refer to the following: Add Additional Symbol Bar Difference Sum - Bar -- You can also create custom calculated symbols using the IB symbols. But there is no way to specify a wildcard for ATM. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-23 12:07:38] |
Sierra_Chart Engineering - Posts: 17195 |
Regarding Interactive Brokers symbols, refer to: Interactive Brokers Symbols Additionally Sierra Chart it has no support for Interactive Brokers combination symbols, or whatever the terminology they use for those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
