Date/Time: Wed, 27 Nov 2024 16:34:02 +0000
Compare ETF to Futures
View Count: 340
[2023-07-21 15:39:55]
User657837 - Posts: 6
Hi does anyone know how to compare ETF levels to the Futures levels? For example if I wanted to know what SPY 431.39 is equivalent to on ES via a chart? I'm aware of doing the rough math just wanted to know if somehow you can put prices levels of say SPY on the left and ES on the right and then the crosshairs will show the values as you move it around. Thanks
[2023-07-21 17:56:39]
John - SC Support - Posts: 36322
Use the "Add Additional Symbol" study to get the two symbols on the same chart and set this study to be an "Independent" scale with the option for "Use in Left Side Scale" enabled, and then use the Left Side Scale option to display the scale on the left for the additional symbol.
Refer to the following:
Chart Scale and Scale Adjusting: Use In Left Side Scale
Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu)
[2023-07-23 15:46:42]
Sierra_Chart Engineering - Posts: 17195
For Add Additional Symbol, refer to:
