Date/Time: Wed, 27 Nov 2024 16:36:43 +0000
Is Cumulative Delta Bars - Volume horizontal delta?
View Count: 271
[2023-07-21 15:38:22] |
TriStar Trading - Posts: 142 |
Is the Cumulative Delta Bars - Volume study calculated using horizontal delta? If so, would it ever be considered to have an option for diagonal delta? Thanks, Mike
[2023-07-21 17:52:03] |
John - SC Support - Posts: 36322 |
The information for how calculations are done for any study are in the documentation for the studies. You will find the Cumulative Delta Bars - Volume at the following link: Cumulative Delta Bars - Volume In this case, the calculation is a total difference, not a per price total. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
