Date/Time: Wed, 27 Nov 2024 16:58:53 +0000
ticks per second/volume per second alert
View Count: 515
[2023-07-21 14:34:37] |
User774712 - Posts: 13 |
hi do you have any study that sends me an alert whenever the price moves by a certain ammout of ticks in 1/2 seconds? (like in the picture the price moved by 9 ticks in 2 seconds) or if there is a way it will send me an alert whenever a certain number of volume is exceeded in 1 second? |
heatmap.png / V - Attached On 2023-07-21 14:30:18 UTC - Size: 10.88 KB - 102 views |
[2023-07-21 15:05:05] |
John - SC Support - Posts: 36325 |
You might be able to do this with a Spreadsheet Study and a 1 Trade chart. You would have to check the time and find the period in which the half-second has passed and then you can use the Offset to find the prices at those two periods to find the tick difference. Another option would be use a half-second chart and test each bar, but this only gives you the movement if it occurs within that particular half-second. The same would be true for the volume. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-21 16:23:08] |
is it possible to set the alert of the number bar calculated value on a 1 second chart to send an alert if a certain amount of volume is exceeded? if yes how?
[2023-07-21 18:04:01] |
If the chart is a 1 second chart, then you would just do the following for the alert: = V > 1000 Where 1000 is a representation of whatever value you want. There is not a way to do this sub-bar without reverting back to what we referenced previously. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
