Date/Time: Sat, 15 Aug 2026 07:10:13 +0000
Get Value from Object without Reference
View Count: 930
| [2023-07-21 10:14:04] |
| Bartezz - Posts: 18 |
Hi Team, i try to get Value from Object, store it to variable to use this value later, but if the Value of object is changed, then the value of this variable is changing as well (also all older Messelogs). How can i get Value from this Object without any changing? Here is my Code s_MarketDepthEntry DepthEntryBid; s_MarketDepthEntry DepthEntryAsk; sc.GetBidMarketDepthEntryAtLevel(DepthEntryBid, 0); sc.GetAskMarketDepthEntryAtLevel(DepthEntryAsk, 0); Last_Bid_Limit_Size = DepthEntryBid.Quantity; Last_Ask_Limit_Size = DepthEntryAsk.Quantity; Regards |
| [2023-07-21 12:15:09] |
| Sierra_Chart Engineering - Posts: 24564 |
This will not be the case: but if the Value of object is changed, then the value of this variable is changing as well
However, if this code is executing every time you are using a copy of a value, then you are always getting the current depth values: s_MarketDepthEntry DepthEntryBid; s_MarketDepthEntry DepthEntryAsk; sc.GetBidMarketDepthEntryAtLevel(DepthEntryBid, 0); sc.GetAskMarketDepthEntryAtLevel(DepthEntryAsk, 0); Last_Bid_Limit_Size = DepthEntryBid.Quantity; Last_Ask_Limit_Size = DepthEntryAsk.Quantity; You may want to look at persistent variables: ACSIL Interface Members - Functions: Persistent Variable Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
