Date/Time: Wed, 27 Nov 2024 16:53:42 +0000
Enable DLL
View Count: 312
[2023-07-21 01:27:55]
User112814 - Posts: 5
Hi how do I enable ddl? I created a custom study but I do not see it listed.
[2023-07-21 01:28:52]
DLL**
[2023-07-21 13:39:47]
John - SC Support - Posts: 36323
The .dll file needs to be in the 'Data' folder which is located directly under your Sierra Chart main installation folder (typically this would be C:\SierraChart, but it depends on where you put it).
Then refer to the following for how to open the study:
Chart Studies: Add Custom Study
