Date/Time: Wed, 27 Nov 2024 16:46:33 +0000
config file?
View Count: 339
[2023-07-20 08:20:27] |
Chris_Janowski - Posts: 5 |
Hello, I am using Sierra for many months so far and I am great enthusiast of it. I spent long hours adjusting Sierra for my needs and it works perfect. Now I plan to buy a new PC and install Sierra on it. I would not like to spend again long hours by adjusting and configuring my charts, tools etc so my question is : is there any config file (to be found within files of Sierra on my HDD) that I could copy from my old PC and paste into my new PC after havin Sierra installed? It would be great to avoid all the work done with adjusting tools, charts etc. Please let me know. Greetings, Chris.
[2023-07-20 09:31:54] |
Sierra_Chart Engineering - Posts: 17195 |
Yes. This is all documented on this page: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
