Date/Time: Wed, 27 Nov 2024 16:49:09 +0000
Converting file
View Count: 273
[2023-07-19 17:30:11] |
User993100 - Posts: 1 |
Hello, I tried to open a customised chartbook but it says it is not compatible, that I need your help to convert it so it can run. Can you help? Thank you |
[2023-07-19 18:13:00] |
John - SC Support - Posts: 36322 |
We will no longer update the chartbooks from G7FX. Follow the instructions at the following link to update it: Chartbooks (Workspaces): Opening Older Chartbooks Or you can get an updated version from G7FX. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
