Date/Time: Wed, 27 Nov 2024 16:37:45 +0000
Teton Streaming 3-4 Seconds Behind
View Count: 274
[2023-07-19 15:17:00]
Tony - Posts: 519
I noticed this morning, Teton streaming was uninterrupted but 3-4 seconds behind, it didn't catch up until I disconnect and reconnect data feed multiple times. This had happened before, but quite a while ago, wonder what might cause the issue?
Use Real-Time Data Compression: High Compression
Remote Buffer Delay Send Time in Milliseconds: 250
[2023-07-19 15:44:10]
Sierra_Chart Engineering - Posts: 17195
Are you using Wine?
If so we will be adding a workaround.
Date Time Of Last Edit: 2023-07-19 15:44:56
[2023-07-19 16:39:40]
Tony - Posts: 519
Yes, Wine + LMDE5
Thanks so much for taking care of this, guys!
