Date/Time: Wed, 27 Nov 2024 16:57:58 +0000
profondeur du marché
View Count: 320
[2023-07-19 12:34:00] |
User338651 - Posts: 14 |
bonjour , je n'est pas la profondeur du marché sur mon DOM je vous remercie d'avance de m'aider cordialement |
[2023-07-19 15:47:34] |
John - SC Support - Posts: 36324 |
From Google Translate: hello , I is not the depth of the market on my DOM
You are not subscribed to an exchange that includes the Market Depth data. Right now, the only exchange you have active is the "Full CME Group for Non-Professional Trading Accounts". You would need to have activated an exchange that includes the Market Depth data (which is in the name of the exchange) to get the Market Depth data. You can change your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Note that if you only need Market Depth data for some symbols (such as only ES and MES, or only for those that are traded on the CME exchange) then you could simply add the "CME with Market Depth" exchange option and keep the other exchange that you have active in order to get the data for the rest of the CME Group. Also, be aware that the exchange fees are not pro-rated and the exchanges do not give refunds. Therefore, if you deactivate an exchange, you will not get a refund for the remaining time in the month (actually, you still have access to that data through the end of the month). And, if you activate an exchange now, you will pay the full amount for the exchange to get the data through the end of the month, then pay again on the first day of next month for that month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
