Date/Time: Wed, 27 Nov 2024 16:46:37 +0000
How to use add additional symbol studies and get scale aligned with chart
View Count: 328
[2023-07-17 19:08:46]
User392433 - Posts: 42
I want to use add additional symbol studies for multiple symbols and add it to the chart, but have the scale be fixed to the main price chart. Right now, the additional symbols scale gets thrown off if you scroll to different parts of the chart.
Also, I would like this to still be scaled to the main price chart when I combine these symbols in study subgraph average.
How do I do this?
[2023-07-17 20:15:10]
John - SC Support - Posts: 36322
We are not really sure how you are wanting to view the data. But if you are using "Add Additional Symbol" studies to Region 1, where the Main Price Chart is located, then the Scale for the "Add Additional Symbol" would need to be set to "Independent" in order to not cause an issue for the scales overall.
[2023-07-17 21:32:04]
So I already put it as independent scale and having the price changes have their own scale is fine, but I would like the scale of main price graph and the additional symbols scale to be relative to each other.
Almost like a projection of the additional symbols price graph into the space of the main price graph. So the slopes can be independent, but the position of the additional symbols would be fixed relative to the main price graph.
[2023-07-17 21:59:03]
There is not a way to force the "Add Additional Symbol" to tie to a particular point against the main price graph.
You might want to look at the "Percent Change since Open" study, which will always start at 1.00 for all charts, so you can use this for each additional symbol to view the relative scale. Refer to the following:
Percent Change Since Open
