Date/Time: Wed, 27 Nov 2024 17:49:32 +0000
P/L completely wrong
View Count: 233
[2023-07-17 16:09:28] |
User478940 - Posts: 1 |
Good morning, Recently on my current account the P/L is completely wrong, the values are wrong 21T in loss while the only trade I made is a winner? Thanks in advance Translated from: Bonjour, Depuis peu sur mon compte actuel le P/L est complètement faux, les valeurs sont fausses 21T en perte alors que le seul trade que j'ai passé est gagnant? Merci d'avance |
[2023-07-17 19:22:34] |
Sierra_Chart Engineering - Posts: 17195 |
There are different Profit/Loss values. We are are not sure which one you are referring to. Refer to: Help With Daily Profit/Loss Value Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
