Date/Time: Wed, 27 Nov 2024 17:39:59 +0000
trying to set up my DOM
View Count: 216
[2023-07-17 15:25:45] |
ARBELASIGMA - Posts: 1 |
Hi I’m trying to set up my DOM But when I try to change colors The colors don’t change Is this because is a trail version ? Sent from my iPhone |
[2023-07-17 19:59:33] |
John - SC Support - Posts: 36329 |
This has nothing to do with being on a trial. Most likely you are changing the Chart specific graphics settings when the chart is not setup to do so, or vice versa. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
