Date/Time: Wed, 27 Nov 2024 16:58:17 +0000
build a formula for triger an alert
View Count: 254
[2023-07-17 12:36:19]
User278398 - Posts: 291
hello,
i want to triger an alert if a value that i get from other formula (id1.sg1) with "spreadsheet formula" study
(for example, ask volume) is 100% more higher then the last value i got.
for example:
if i got the value 44468: (pic 1) at 9:39:56
and
i got the value: 111105 (pic 2) at 9:39:57
(which is 100% more then 44468)
so i want the Triger will happen (at 9:39:57).
what is the formula i need to build?
regards.
Date Time Of Last Edit: 2023-07-17 12:38:12
image1.png / V - Attached On 2023-07-17 12:32:07 UTC - Size: 14.58 KB - 74 views
image2.png / V - Attached On 2023-07-17 12:32:12 UTC - Size: 12.35 KB - 84 views
[2023-07-17 19:26:48]
John - SC Support - Posts: 36324
Are these two values in different bars? In other words, is the formula you want the following when using 1 second bars:
- When the current bar has a value that is twice as large as the previous bar
The formula for this would be:
=ID1.SG1 > 2 * ID1.SG1[-1]
Or is this Intrabar, the value is one thing then changes to another within a single bar? There is not a way to do this using the Sierra Chart tools. You would have create a custom study
[2023-07-18 14:44:52]
i got this data from 1 min chart
and i display it in other chart (1 second chart)...
u sent me a formula which connect to every bar.
there is formula which connect to time?
this can work?
regards
[2023-07-18 17:01:30]
In order to create an alert using Time, you would have to use the "Spreadsheet System/Alert". Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
And refer to the following as well as the other functions (specifically time-related functions) on this page:
Spreadsheet Functions: Serial DateTime Values
